Login  •  Register
  >>Reviews >> Drivetrain >>Cranksets >>
FSA K-Force Light Carbon
Best Reviewed in This Category:
Description
  • Bladder molded hollow carbon monocoque arm/spider
  • Features FSA Ceramic cartridge bearings with smoother, lighter balls (new narrower overall width for a lower Q factor and the bearing...
  • More [+]
    Read the Reviews >>     Write a Review >>
    Buy It Here
    JensonUSA
    15% OFF YOUR FIRST ORDER
    Buy It Here
    Gotta Ride Bikes
    Click here for Hot Deals >>
    Shop for Similar Products
    Performance
    Review Options:  Sorted by Latest Review | Sort by Best Rating
    Reviews 1 - 4 (4 Reviews Total)
    Reviewed by:
    Brian Nystrom
    Review Date
    July 2, 2008
    Overall Rating
     5 of 5
    Value Rating
     4 of 5
    Used product for
    Less than 1 month
    Rate this review?
    Shop for this product >>
    Price Paid:  $440.00 at BeyondBikes.com
    Bike Setup:
    '94 Lemond Ti, Campy Chorus shifters and derailleurs
    Summary:
    These are my initial impressions of the FSA K-Force Light Compact Crank. I recently bought two of these and installed one this past weekend.
    - It's light - They claim 660 grams with the BB. My two weighed 668 and 675. It knocked exactly half a pound off the bike I installed it on.
    - Installation was easy - However, if you don't own a torque wrench, buy or borrow one before installing the crank as the specified 36 ft/lbs is a lot more torque than you think. I was starting to get nervous about over-tightening it when the torque wrench finally clicked.
    - The Q-factor is pretty narrow - I noticed the difference, but it wasn't uncomfortable. I'm sure it's not the narrowest crank on the market, but it's narrower than what I had before.
    - It's very stiff - I'm really surprised how different the bike feels with the new crank. Apparently, the frame is stiffer than I thought and much of the flex I felt was in the old crank/bb combination.
    - I like the compact gearing (34/50). The lower gear I gained will be quite useful. I did spin out on one downhill, but I was doing over 35 mph at the time. My other bike will have a 12-23 ten speed cassette instead of the 13-13 nine speed on this one, so I won't lose anything top end compared to what I had before (53/39 with a 13-23 cassette).
    The ceramic bearings in the bb make a HUGE difference and I can ride at least two gears higher! ... Just kidding - ceramic bearings on bikes are a joke - but the bright red cups sure do look fast! ;-)
    So far, I like it a lot. Time will tell as to how well it holds up.
    Strengths:
    Light weight
    Easy intallation (if you have a torque wrench)
    Very stiff
    Weaknesses:
    None so far
    Buy
    Would you like to Comment?
    Join RoadbikeReview for a free account, or Login if you are already a member.
    Reviewed by:
    mla
    Review Date
    June 28, 2008
    Overall Rating
     3 of 5
    Value Rating
     3 of 5
    Used product for
    1 Year
    Rate this review?
    Price Paid:  $5.00 at LBS
    Favorite Ride:
    too many
    Bike Setup:
    Trek 03 5900
    Summary:
    Like the crankset very much, and thought the crank was perfect, then this week on an easy ride I thought my pedal was getting loose, turned out the metal pedal insert in the crank arm was loose. Checked the other and it was a little loose also. Have not switched or removed the DA 7800 pedals since the crank was installed, so no clue why the inserts came loose. Contacted FSA so we will see if they replace the crank under warrantee. I do like the crank very much
    Strengths:
    Light, strong, ceramic bearing BB
    Weaknesses:
    Non except crank arm pedal inserts, and maybe this was an early model that fsa has corrected????
    Similar Products Used:
    shimano, fsa
    Buy
    Reviewed by:
    jpcribari
    Review Date
    May 12, 2008
    Overall Rating
     5 of 5
    Value Rating
     4 of 5
    Used product for
    3 months
    Rate this review?
    Price Paid:  $550.00
    Favorite Ride:
    Lasal Loop
    Bike Setup:
    Moots Phychlo-X with a mix of Campy Chorus and Record and some sweet old XTR canti brakes.
    Summary:
    Awesome crankset! I have been riding for 25 years now and I have used and worked on just about everything out there and this setup is the best yet. Follow the installation instructions and do your regular maintenance, (i.e. check your non drive side crank bolt every few rides) and you will not be disappointed. I have this crank on my MOOTS Psychlo-X and I have been riding a lot of dirt, singletrack and pavement and it has worked flawlessly. The ceramic bearings are smooth as silk and the rings shift great not to mention it is great looking.
    Enough Said.
    Strengths:
    See Summary.
    Weaknesses:
    It doesn't morph into a beautiful woman after every ride.
    pretty much everything
    Buy
    Reviewed by:
    chrldrcar
    Review Date
    April 9, 2008
    Overall Rating
     1 of 5
    Value Rating
     1 of 5
    Used product for
    Less than 1 month
    Rate this review?
    Price Paid:  $599.00 at QBP
    Bike Setup:
    Scott Addict R4, Dura-Ace, XXX lite Clinchers, Zero Gravity, CARBON
    Summary:
    After installing on a new Scott Addict frame there is no possible way to get the bottom 4 cogs to work in the small ring. I can understand the bottom cog but not 4. Contacted FSA and they were no help at all. Now I have a very expensive crankset that is pretty much useless.
    Strengths:
    lightweight, shiny, pretty, doorstop
    Weaknesses:
    doesn't work correctly, expensive, doorstop
    Bontrager carbon, old FSA Carbon, Dura-Ace
    Buy
    Schwinn Madison
    SRAM Rival Groupset
    Pedal Force RS2
    Jamis Xenith Team
    LOOK 566 Preview
    Specialized Ruby Expert
    Campagnolo Super Record
    VCRC Ceramic Bottom Bracket
    Fulcrum Racing 1 Wheelset
    Vittoria Open Pave EVO CG
    LED Light Shootout!
    LED Light Shootout
    View Here
    Advertise With Us | About Us | Contact Us | Privacy Policy | Terms Of Use The ConsumerREVIEW.com Network
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
